How do you change the text color of the bar on a Gantt chart?
  • 11 April 2019
  • 222 views
Userlevel 4
Badge
  • 57 replies
I have a Gantt chart in WinUI that I'm trying to replicate in WebUI. The bars are colored based on the data (and a small bit of logic). I also have text on the bars.
The only way I can find to make sure the text shows up is change the css. But the text doesn't respond to anything but the stroke property.
Here's the css, and below is the result:
code:
.aimms-widget .tag-ganttchart .annotation-Red_100\% {
stroke: black;
fill: rgb(255,50,50);
.aimms-widget .tag-ganttchart .annotation-Green_100\% {
stroke: white;
fill: rgb(50,255,50);
.aimms-widget .tag-ganttchart .annotation-Blue_100\% {
stroke: white;
fill: rgb(50,50,255);
.aimms-widget .tag-ganttchart .annotation-Orange_100\% {
stroke: black;
fill: rgb(255,153,50);
Is there any other way to change the text without also having the stroke around the bar change?
~Bon
Best answer by Imke 23 April 2019, 12:48
Userlevel 4
Badge
More information on the font color situation...
The fill property fills both the bar and the text, BUT when you hover, it only fills the bar (and not the text):
Hi @MathFour
We're currently looking into this and will get back with more information as soon as we can!
Userlevel 1
Badge
Hi @MathFour ,
We use
.aimms-widget .tag-ganttchart .bar.annotation-Red {
stroke: (for border)
fill: (for background)
.aimms-widget .tag-ganttchart .label.annotation-Red {
fill: (for text color)
Maybe that helps?
