I was wondering if it is possible to change the shape of the node on the map from a circle to something different, e.g. a square or triangle? I am already using color coding to indicate allocation of store locations to warehouses, the shape is intended to differentiate between 3 different types of stores.
Using of icons or alterntative stroke colors doesn't really work, because the nodes need to be quite small. But I am also interested in any other suggestions to make it work.
Best answer by Pratap Kumble
