Dear All,
I want to develop Routing Problem Model using Ant-Colony method, does AIMMS possible to generate the method? Are there any example that anyone could share..?
Thank you very much
Dear All,
Thank you very much
Thanks for the question Farhan
We’ve recently used an ant colony optimization method in our just released demand forecasting app. In this app we use it to refine the forecast model each period when we get new actual demand data.
I’m not the developer but my understanding is this was coded directly in AIMMS, perhaps
Thanks
Brian
Dear Farhan,
it is indeed possible to create a routing problem model using ant colony optimization in AIMMS. Basically, you need to create processes to care about the followings:
If you have any further questions, you can share them with us.
Zsolti
Dear Farhan,
It is another possibility to use premade libraries to solve the Routing Problem Model.
if you mean TSP by Routing Problem Model, you can use some python libraries (e.g. acopy, ACO-pants). If it is rather a VRP, you can use some R libraries (e.g. antcolony.lavaan, evoper).
In AIMMS, you can execute python and R scripts.
How to execute a python script in AIMMS: https://how-to.aimms.com/Articles/114/114-execute.html
How to execute an R script in AIMMS: https://manual.aimms.com/rlink/
Zsolti
Thanks
Yes, I’m creating a VRP model, Multi-depot with inter-facilities. Currently I have the educational version of AIMMS, is it possible to add the R libraries? or is it only for Pro version..?
Looking at your question, you could also be interested in the AIMMS-MOPTA modeling competition… create a team and participate. All information can be found here:
Hi
Hi
Please know the R link doc shows an example on how to use it (Iris). Online there is all kinds of literature on using ACO for Vehicle Routing. AIMMS itself has tutorials on how to create models and loads of other specifics, including a set of examples including routing (see link below). If you combine those three sources, you should be able to build what you need.
https://www.aimms.com/english/developers/resources/examples/practical-examples
If this is not sufficient, maybe it’s best to share what you have so far and ask what you are missing so people can pitch in.
Hi
It looks like there are some conflicting constraints which are making the model infeasible but we cannot debug further without knowing what your variables and constraints represent / the symbolic formulation of your model. constraints highlighted in blue are infeasible, I am suspecting FlowBalance and DemandConstraint are not declared properly
Do you have an paper/source for the ACO algorithm ? If yes, we could guide you on how to implement that
Hi
Thanks for your reply, actually I’m trying to develop Multi-depot Green VRP with inter facilities. So the main idea is products could be transfered directly from “Kilang” (depot) to “Depot” (customer), and also to “Terminal” (Inter Facilities) to buffer some products. Since it is multiobjective, least cost and emission, I create Fuel consumption variable to calculate either least cost and emission based on distance matrix, but the model that I already attached still focusing least cost problem.
Here i attached paper about ACO Algorithm
