Terminated by The Solver
  • 26 April 2024
  • 9 replies
  • 81 views
Badge +1
I am solving a huge MIP (4446310 integer variables). I set the relative gap to 0% from CPLEX MIP settings. After 69532.16 sec (19.3 hours), the model stops running and the solver status says 'Terminated by solver' while the gap is 0.14%. Why does this happen? What are the possible causes? Thank you.
Best regards,
Wanie Saidi
Best answer by Marcel Hunting 26 April 2024, 11:09
Badge +4
HI @Wanie Saidi. Probably CPLEX ran out of memory. I strongly recommend to print the CPLEX status file by setting the following options:
  • CPLEX option 'Parameter display' to 'Yes'
The CPLEX status file will be printed in the log folder. It contains useful information about the solving process. See also this topic.
Badge +1
Thank you @Marcel Hunting for the recommendations. I’d like to understand if this issue is solely due to CPLEX running out of memory, or if there might be other factors contributing to the problem. Could you provide further insights into possible alternative causes that could lead to the issues?
Best regards,
Wanie Saidi
Badge +4
Hi @Wanie Saidi. The only realistic possible cause that I see is lack of memory (or lack of disk space, if the node file is written on disk). The CPLEX status file should tell you more.
Badge +1
Where is the option to open the log folder in AIMMS?
Badge +4
Hi @Wanie Saidi. You can open the log folder using the File Explorer. It is a sub-folder inside the folder with the AIMMS project. The CPLEX status file can be opened with a text editor like Notepad.
Note that you can open the CPLEX status file inside AIMMS by selecting File - Open - Text File, select All Files instead of Text Files (bottom-right), browse to the log folder, and select, e.g., 'CPLEX 22.1.sta'.
Badge +1
Is it this folder?
Badge +4
That is the correct folder. Please note that the CPLEX status file will be emptied if you re-open the AIMMS project, so you might want to copy it after the solve.
Badge +1
This is the CPLEX status file that I got after the model stopped running. Solver status shows ‘Terminated by Solver’ with the gap 0.15%. It seems that it is because there is not enough memory from the CPLEX status file. Can you give a detailed explanation about the other information in this status file?
Badge +1
