Bound Tolerance Problem
  • 11 November 2022
  • 99 views
HELP!!!
We are students and we have an error message that we cannot understand.
We know that 500 is the parameter DemOp2 for j=1 (the 1st month).
We tried everything we could to solve the problem to have a solution but nothing works.
If anyone could help us, we would be infinitely grateful.
Thank you so much.
Best answer by mohansx 11 November 2022, 17:30
Badge +5
I think it is just a problem with how the constraint is written with mismatching indexes.
Constraint CDemOp2(i, j) has a definition DProd(i|i=2, j) = DemOp2(j)
The mismatch is between CDemOp2(i, j) and DProd(i|i=2, j)
When i=1 and j=1, the condition i|i=2 will be false (it will be true only when i = 2), so the constraint definition will essentially be 0 = DemOp2(1), which is the error you are seeing.
What is the logic behind DProd(i|i=2, j) ? Your current constraint essentially models
CDemOp2(j) with definition DProd(2, j) = DemOp2(j)
Userlevel 6
Badge +6
My assumption is that you want to limit the constraint domain to only generating constraints where i=2. You can do this by defining the index domain of CDemOp2 as
    (i, j)|(i=2)
and the definition then as
   DProd(i, j) = DemOp2(j)
Now there are only constraints generated for i=2 and all j.
Thanks everybody !!
We found our problem
