Hey everybody,
I have a small question. Is it possible to define a parameter in relation to a Variable.
I want to use this parameter in a Constraint.
For example If the optimization variable is 5 - the parameter has to take the value 1.8.
If the variabel is 2, the parameter has to have the value 1.3.
I guess most likely it is possible to use a if- or switch-Function, but I am not sure…
Can I load a table with these parameters in Aimms, so that he can give the parameter the right value, or are their any other ways to do this?
Thanks a lot in advance!
