Question
Best LP Bound on different systems
  • 23 March 2021
  • 34 views
Badge
how is it possible to obtain a worse outcome on a more powerful PC system? Are there solver options which are benefitial for a faster PC system?
In my specific case, I run a Mathematical Program (MIP) minimizing a target function. Since the computation effort is quite high, I introduce an Upper Bound to reduce the solution set. However, if I run the identical probelm instance on two systems, the more powerful one is not able to even calculate a Lower Bound. I use CPLEX 20.1. Any idea why this could be or how to configure solver options?
Thanks and best regards
Userlevel 4
Badge +1
Hi @inkognitro. It would be a good idea to print the CPLEX status file for both runs. It will be printed in the log folder if you set the following options:
  • Solvers General option 'Solver listing messages' to 'All';
  • CPLEX option 'MIP display' to 'Nth node + info on node cuts';
Comparing the CPLEX status files might provide some useful information. I invite you to share them here.
How did you introduce an upper bound? By providing a MIP start?
Hi @inkognitro
Did Marcel’s answer help you with your issue?
