Does AIMMS store the information after an user triggers multiple upon change procedures.
For example, 2 parameters are in a UI table and an user uses block editing to change both parameter , both wiht their own upon change procedure.
Can you know as a developer during the first one that called that also a second will be called later.
(i know the order depends on the model tree)
Best answer by luispinto
