If statement in constraint
  • 5 July 2019
  • 2110 views
Dear all,
In my model, I work with multiple factories. Each factory has a minimum lotsize requirement, meaning that IF a product run is initiated, it must be at least xxx big. I tried to put it in as follows:
  • I have a parameter MinimumSKULotsize(f), which specifies the minimum lotsize per factory;
  • I have a binary variable ProductInFactory(f,p,t), where 1 indicates a production run of that product at that factory in that time unit, and 0 does not.
  • I have a variable ProductionAllocation(p,f,t) which indicates how much of each product is allocated to which factory at which time unit.
I tried to add the constraints:
SKULotsizeConstraint0 with index (f,p,t) | ProductInFactory(f,p,t) = 0 and definition
ProductionAllocation(f,p,t) = 0
SKULotsizeConstraint1 with index (f,p,t) | ProductInFactory(f,p,t) = 1 and definition
ProductionAllocation(f,p,t) >= MinSKULotsize(f)
However, I am getting the warning: Warning: The index domain contains the variable "ProductInFactory". The use of a variable in an index domain is not allowed.
Before this, I tried to do it with an if-statement, but then I was also met with several errors. My question is: how could I correctly apply such a constraint in this situation?
Kind regards,
Koen
Best answer by deannezhang 8 July 2019, 06:17
Userlevel 4
Badge +3
Koen,
Domain condition can only contain parameters. Variables cannot be used as domain condition. You need to linearize your constraint:
if ProductInFactory(f,p,t) = 0 then ProductionAllocation(f,p,t) = 0
if ProductInFactory(f,p,t) = 1 then ProductionAllocation(f,p,t) >= MinSKULotsize(f)
trying yourself first, if not people here can help
Userlevel 6
Badge +6
Hi @KoenV did this answer your question? If so would you please mark "best answer" so others can find it easily? Thanks 🙂
Koen,
hello.. how to write the constraint like this in the model? should I write it in the constraint or in the variable?
In my model there is a binary variable x_jm(i,m,k,t) means that route selection from i to m using ship k in t time. And there is a positive variable UF(k) which is the Utilisation Factor of ship k. There are some ships in index k, not all of them to be selected/used. So once ship k (let’s say ship k1 and k2) are selected then those ships must have utilistation factor UF(k) above 0.7.
I put the constraint like below picture but there is a warning.
Could somebody help me how to write it in the model?
Thanks.
Regards,
Ardhana
Badge +4
HI @ardhanaa. You cannot formulate this in one constraint or variable definition. You can reformulate it by using the following constraints:
sum[(i,m,t), x_jm(i,m,k,t)] >= b(k)
sum[(i,m,t), x_jm(i,m,k,t)] <= M * b(k)
UF(k) >= 0.7 * b(k)
UF(k) <= N * b(k)
Here b(k) is a (new) binary variable, and M and N are upper bounds on sum[(i,m,t), x_jm(i,m,k,t)] and UF(k) respectively.
