I want to map data from an Excel file using DEX ExcelSheetMapping to a parameter named “Capacity”.
However, I cannot get that null (“0”) values are read into the parameter “Capacity”.
I have a constraint that imposes an upper limit over a variable named Stock, as follows:
Stock <= Capacity
I need to read null (“0”) values to impose that the variable Stock is null.
How can I do it?
Thank you
PS: I omit indexes for the sake of simplicity
Best answer by luispinto
