root set issue while adding element to set using setelementadd
  • 7 December 2023
  • 36 views
Badge +3
SetElementAdd(Li_available_section,LE_add_section,Li_required_section);
need add to add elements (Li_required_section-user defined string) to Li_available_section  subset of allsections using element parameter using LE_add_section-subset of allsections.
i am getting below errors.
Domain mismatch in argument 2: the set "LS_required_sections" does not share the same root set as "LS_available_sections" on argument 1.
it will be helpful if you can provide solution
Best answer by gdiepen 7 December 2023, 22:32
Badge +7
The second argument you provide to the SetElementAdd function (LE_add_section) in your case should be an element parameter that shares the same rootset  as the set of the first Li_Available_section argument.
You cannot have a call like SetElementAdd(setCities, elementParameterNewPerson, “Haarlem”)
if the subset of attribute of elementParameterNewPerson is not the same as the rootset of the set setCities
Badge +3
Li_available_section is subset of set of index Li_required_section. Ithink it shares same root
Badge +7
Can you maybe share screenshots of the attributes of the identifiers involved? So the different sets, the element parameter and the procedure?
Badge +3
i solved this issue. thanks for your time
