Question
Help on customization in Map widget - remove default stroke color black when clicked on any node/location
  • 6 October 2021
  • 62 views
Badge
Hello everyone!
Is it possible to remove the default stroke color (black) when user clicks or selects any node/location which has already defined stroke color? This is so that the customized stoke colors (defined in model) for the nodes remain functional even when any node is selected. I see customized stroke colors appear back when clicked twice on any node.
In my case, by clicking on any location, the stroke colors are turned off and default stroke color black turns on. By clicking on same location again, we can see all stroke colors for potential locations(orange) and optimal location(red). Please find attached screenshots for reference.
Thanks in advance for help on this case!
Userlevel 3
Badge
Hi @saurabh_1006
  The attachements are not available, can you re-send? But if I understood correctly, you would like to change the black color of a node once you select it, right?
