Hi all!
I built a feasible model in SG Navigator with 21 production plants and a detailed BOM per item and location. However, I must add constraints related to the total production per item and location during the period of analysis.
I tried three ways but any of them worked:
- Adding Minimum capacity and Force Open = 1 in the Production Sheet + Adding Minimum capacity per Location and Item in the Production Routing Sheet. Result = The model was infeasible
- Adding Maximum capacity in the Production Sheet + Adding Minimum capacity per Location and Item in the Production Routing Sheet. Result = The model does not respect all of the constraints
- Adding Minimum capacity and Maximum capacity (both of them with the same quantities) in the Production Sheet + Production Routing Sheet. Result = The model was infeasible
How should I model those constraints?
Best answer by Facundo.Olivero
