How to retrieve MIP Optimality Gap an Solving Time into a Parameter
  • 4 January 2020
  • 432 views
Userlevel 2
Badge +4
Dear All,
Is possible to retrieve MIP optimalilty gap and Solving Time for each solve in to a parameter?
If so, how to do this?
Thank you very much.
Best answer by deannezhang 5 January 2020, 01:03
Userlevel 4
Badge +3
You can use the “Incumbent” and “Incumbent” suffix to retrieve the best known solution and the  LP bound, then use them to calculate the GAP and assign it to a parameter.
MpGap :=(abs(MathProgram.Incumbent - MathProgram.bestbound)/$abs(MathProgram.Incumbent)) * 100;
Userlevel 2
Badge +4
Hello @deannezhang,
Thank you for the method to calculate the gap. For solving time, is there a way to retrieve it?
Thank you.
Userlevel 4
Badge +3
Yes, you can use the “SolutionTime” suffix. For other suffix and callback functions, you can refer to the AIMMS Language reference, part “Suffices and Callbacks”.
Userlevel 2
Badge +4
Hi @deannezhang,
Thanks a lot….
