How to retrieve MIP Optimality Gap an Solving Time into a Parameter
  • Jan 4, 2020 9:19 AM UTC
  • 552 views
rahmat
Dear All,
Is possible to retrieve MIP optimalilty gap and Solving Time for each solve in to a parameter?
If so, how to do this?
Thank you very much.
Best answer by deannezhang
You can use the “Incumbent” and “Incumbent” suffix to retrieve the best known solution and the  LP bound, then use them to calculate the GAP and assign it to a parameter.
MpGap :=(abs(MathProgram.Incumbent - MathProgram.bestbound)/$abs(MathProgram.Incumbent)) * 100;
deannezhang
  • Jan 5, 2020 12:03 AM UTC
rahmat
  • Ace
  • Jan 6, 2020 12:46 AM UTC
Hello @deannezhang,
Thank you for the method to calculate the gap. For solving time, is there a way to retrieve it?
Thank you.
deannezhang
  • Jan 6, 2020 8:12 AM UTC
Yes, you can use the “SolutionTime” suffix. For other suffix and callback functions, you can refer to the AIMMS Language reference, part “Suffices and Callbacks”.
rahmat
  • Ace
  • Jan 7, 2020 1:12 AM UTC
Hi @deannezhang,
Thanks a lot….
