How to check if variable values satisfy constraints
  • Mar 28, 2019 10:08 AM UTC
  • 82 views
User Support
This article explains how to check whether a given combination of value assignments for the variables in your model satisfy all the constraints to produce a feasible solution.
You could add an assignment constraint for each of your variables that fixes the variable to the given value and then solve the model again. If the solver returns with the status infeasible, you know that these variable values do not satisfy all constraints.
Click here
