I have a question with the following: I want to concatenate the values from variables: var1 and var2 into var_new. For example:
var1={1,2,3,4}
var2={5,6}
var_new={1,2,3,4,5,6}
How do I do that?
Thank you in advance!
Page 1 / 1
Hey, how are you?
I don’t fully understand yout use case, but, I read that you want to unite two sets. To do that, you can do via procedure or by definition.
Hi, I am doing well. How are you? Thank you so much for your reply! I appreciate it.
Hmm, I’ve tried that, but since var1 is not a single value, but it’s an array, then the expression var1(n1) +var2(n2) doesn’t seem to work because of the indices.
I just want to extend the first array, adding the second one to it. So not quite sure how to perform that with the indices.
Hi @asimonovska ,
If it is an array, var1 and var2 should have some sort of an index. So are you trying to unite the variable values or the sets? Either way, see if it helps:
for int_numb | var1(int_numb) do SetElementAdd(s_new, ep_new, var1(int_numb)); endfor;
for int_numb | var2(int_numb) do SetElementAdd(s_new, ep_new, var2(int_numb)); endfor;
Thank you Gabriela for helping me out.
Essentially what I want to do is the following:
I have OutputL1_1(n1) or that is my var1(int_numb). This variable is an array of n1 elements.
Then I have OutputL1_2(n2) or that is my var2(int_numb_2). This variable is an array of n2 elements.
What I want to do next is to unite them both so I get: Concat_Output(n3) where n3=n1+n2, and it contains the values of OutputL1_1(n1) and OutputL1_2(n2).
Then I will use this Concat_Output(n3) further as an input in order to get my final output. And I will perform my optimization on top of it.
Now, I don’t know what s_new and ep_new stand for in your equation.
Thank you so much for helping me out!
Already have an account? Login Please use your business or academic e-mail address to register
