Use single Variable defined with two sets (Matrix)
  • 4 April 2022
  • 174 views
Badge
Hello everybody,
I have a little question regarding an optimization problem. In the problem I define my binary variables by use of two sets (matrix). Rows: Set 1, Columns: Set 2.
The first set contains different parts (Set1 contains: Part 1, Part 2, Part 3… and so on)
The second set contains different variants for each part (Set 2 contains: Version 1, Version 2, Version 3 and so on).
The definition of the indices is no problem. Later in the model I want to use not the whole Matrix (Set1 X Set2) but just a Single vector. For example the vector should have the size of Set 1, and of Set 2 just the colum Version 2. So in the constraint I just want to use the yellow colum. Is this possible or do I have to define for every Element of Set 2 an own Set?
Best answer by Marcel Hunting 5 April 2022, 10:25
Badge +4
Hi @Simon Küter. You can define sets using a set expression (as long as the definition attribute of the set is empty or uses initial data). So you can use something like:
Set2 := { Version1 };
solve MP;
Set2 := { Version2 };
solve MP;
The supported set expressions are described here. (Set2 might be a subset of some other set containing all possible versions.)
Badge
Hi @Marcel Hunting ,
thanks again for your help!!
I guess my best choice is to create In the Set 2 the Subsets (Version1, Version2, Version3). This elements of the set are fixed and do not change.
In a constraint I wand to do a skalar vector mulitplication. Until now I did a summation of the whole matrix like sum((Set1, Set2) Variables(Set1,Set2)*Parameter(Set1,Set2)).
Now I want to rebuild that Formula. like.
sum((Set1,Version2)Variables(Set1,Version2)*Parameter(Set1,Version2)) - do I have to define each header of the colums as as Subset or can I use the name of the colums to use the values below?
Badge +4
I think the best approach would be to create a superset of Set2 containing the power set of (Version1, Version2, Version3), and then define Set2 using set expressions. Then there is no need to adjust expression
because the contents of Set2 is defined by a set expression:
This sum will be evaluated for elements in Version2 only.
Badge
Hi @Simon Küter,
Just wanted to check back - did you find the help you needed in this thread, or maybe you found another solution you could share with us? Thank you so much!:)
