AIMMS Calendar (expressing hours)
  • 2 March 2023
  • 37 views
I have a question regarding the calendar. We have an old app implemented based on calendar, in which the hours within a day are expressed as 00 ~ 23. But now we need to change it to 01 ~ 24. Please let us know what the easiest way to do it.
Best answer by Chris Kuip 2 March 2023, 13:01
Badge +7
Hello Mjin,
The AIMMS Calendar does not provision directly for the representation of hours in the range 1..24 instead of 0..23.  To report dates in this range, you can use a string parameter indexed over hours.  When the hour number is 00, then the previous day, with hour 24 is used.  Part of the data of such a string may look as follows:
To implement this string parameter, I used a day calendar with the same time span as the hour calendar as illustrated in the enclosed small example project.
Does this answer your question?
With kind regards,
Chris
PS: I used https://en.wikipedia.org/wiki/24-hour_clock
