AIMMS Calendar (expressing hours)
  • March 2, 2023
  • 99 views
I have a question regarding the calendar. We have an old app implemented based on calendar, in which the hours within a day are expressed as 00 ~ 23. But now we need to change it to 01 ~ 24. Please let us know what the easiest way to do it.
Best answer by Chris Kuip
Hello Mjin,
The AIMMS Calendar does not provision directly for the representation of hours in the range 1..24 instead of 0..23.  To report dates in this range, you can use a string parameter indexed over hours.  When the hour number is 00, then the previous day, with hour 24 is used.  Part of the data of such a string may look as follows:
To implement this string parameter, I used a day calendar with the same time span as the hour calendar as illustrated in the enclosed small example project.
Does this answer your question?
With kind regards,
Chris
PS: I used https://en.wikipedia.org/wiki/24-hour_clock
Chris Kuip
  • March 2, 2023
Hello Mjin,
With kind regards,
Chris
