AIMMS ERROR: Warning: After zero iterations CPLEX 12.7.1 concluded that an integer solution to VRP does not exist.
  • 8 April 2020
  • 466 views
I am currently working on a vehicle routing problem and get this error when i try to run it. Does anyone know how to fix it.
I have also attached the excel file where the data is stored. (Ignore the emission zones column)
Kind regards
Prakash
Badge +5
Hello, you modeled this as MINLP which might not be necessary. Are you required to solve this assignment using a MINLP ? If not, did you review this example ?
https://www.aimms.com/english/developers/resources/examples/practical-examples/vehicle-routing-cvrp/
What are the different constraints that you need to satisfy, like 1. all customer demand must be met, 2. only one vehicle must satisfy all demand at a customer 3. trucks start at and come back to depots etc.
