I am trying to solve an MIP model with AIMMS. I run the AIMMS for a specific parameters and obtained the optimal solution; I also solved the model with same data/parameters using a heuristic to test the optimal solution- it is indeed the optimal. Now I first change the parameters (i.e., using different values) and save the changes in a new "case" using "save case as" option under different name. Then I set the new case as the "active case" and try the model with the new data. surprisingly AIMMS returns the (same) optimal solution obtained with original "case". I used to use the "single file data management" so I thought this might be the reason. I changed this to "disk files and folders" by going to Menu File > Open > Data file>convert...but it didn't help at all.
I also noticed that when I load a case, the model's decision variables contains some values from perhaps previous runs; not sure if this is normal with AIMMS.
Any help on this is greatly appreciated in advance.
Jean
