"binds-existing" attribute from DEX Library Excel
  • 16 August 2023
  • 66 views
Badge +1
The binds-existing attribute can be used in conjunction with the binds-to attribute to indicate that, when reading a data file, no new set elements will be created, allowing for a filtering mechanism where a data file can only be partially read for the nodes that correspond to existing set elements in the model.
I have a predefined set named t with valued {1,2,3,4}.
I want to read an Excel file which contains a column named “time” having values (e.g., 0, 5, 6) not included in the previous set, which I do not want to add to set t.
I am specifying the binds-existing attribute in the DEX mapping as follows:
<ColumnMapping name=”time" binds-existing="t" binds-to="t" />
I have not changed the skip-non-existing attribute, so I was expecting that binds-existing attribute would not add the referred values (0, 5, 6) into the predefined set t. However, it still does.
What am I doing wrong? Did I correctly specify the binds-existing attribute?
Thank you very much
PS: There are almost no specific examples on using DEX attributes. I’ve looked for in the Documentation, the Community, and the internet.
Best answer by Joost 21 August 2023, 11:39
Userlevel 2
Badge
Hi @rmateus , you can specify binds-existing=1, instead of binds-existing=”t” (the binds-to attribute is sufficient for DEX to know how the index is bound). The skip-non-existing attribute you can use with values 0, 1 or 2. Cheers, Joost
Badge +1
Specifying the binds-existing attribute in the DEX mapping as you suggest:
<ColumnMapping name=”time" binds-existing=1 binds-to="t" />
triggers the following error (and the procedure stops):
AddMapping s_parametersMapping: Unable to parse mapping file Mappings/Generated/s_parameters.xml at location 246: Error parsing element attribute
In order to work, I had to specify the argument of the binds-existing attribute between commas as follows:
<ColumnMapping name=”time" binds-existing=”1” binds-to="t" />
 Thank you very much for your reply @Joost!
Userlevel 2
Badge
Hi @rmateus ,
I’m guessing you add this directly in the mapping file?
In that case you need to quote you are right.
Note you can also do this in AIMMS:
dex::ExtraAttributeList( 'indexOfMySet' ) := "binds-existing=1;skip-non-existing=2" ;
Joost
