BOM or no BOM
  • September 2, 2022
  • 62 views
Chris Kuip
Recently one of our customers encountered a REST API that didn't accept Json UTF8 files starting with a Byte Order Mark (BOM). By default, the PUT files created by AIMMS are UTF8 files with a BOM at the start to mark these files as UTF8 files.
There are some ways to circumvent this issue:
  1. Set the hidden AIMMS Project Setting "Default output character set” to UTF8NoBom.
  2. Use the function dex::ConvertFileToEncoding(inputFileinputEncodingouputFileoutputEncodingnoBOM) to convert a file.
  3. The .json files created using dex::WriteToFile(dataFilemappingNamepretty) are UTF8 files without a BOM.
  • 13 replies
  • April 23, 2024
@Chris Kuip, I face the same problem with a customer I want to circumvent the BOM character by changing the project setting, but I can’t select the option ‘UTF8NoBom’ from the list. (using aimms 24.3). Has the option been removed or do I miss something?
Chris Kuip
  • 125 replies
  • April 23, 2024
Hi Marc,
It looks like you are checking the option 'Default output character encoding’ instead of ‘Default output character set’.  Can you check?
With kind regards,
Chris
  • 13 replies
  • April 23, 2024
Yes, my mistake (it was hidden indeed). I found it now, thanks!
