callback procedure that saves new incumbent solution to case file
  • 6 June 2019
  • 128 views
Userlevel 1
Is it possible for a callback procedure to save the newest incumbent solution to a case file.
Is an example available?
Edit:
I already installed a callback procedure (SetCallbackNewIncumbent).
How can I access the new incumbent solution from that procedure?
And do I need to send the new incumbent solution to the model first, after which I can send it to a case file, or can I send it to a case file directly?
Best, WM
Best answer by deannezhang 7 June 2019, 05:16
This topic has been closed for comments
Userlevel 4
Badge +3
In the callback procedure, you can first use function RetrieveCurrentVariableValues to retrieve the variables value from the model;
code:
RetrieveCurrentVariableValues(AllVariables);
Then use the .Incumbent suffix to retrieve the new incumbent value
code:
MyVariable.Incumbent;
Then use function like CaseFileSave to save those values you need.
Userlevel 1
Thanks for your answer, however I get this error...
The function RetrieveCurrentVariableValues cannot be called from a callback issued by GMP::SolverSessionExecute or GMP::SolverSession::AsynchronousExecute.
Any alternatives?
Thanks, W.
Userlevel 4
Badge +3
Hi Wiet, in this case, you may need to use function GMP::Solution::RetrieveFromSolverSession
Userlevel 1
Great, thanks!
