Calling AIMMS from Python
  • October 7, 2019
  • 1181 views
Curious AIMMS-bot
Forum|alt.badge.img+1
Dear Community,
I plan to work from the Python workbench to call AIMMS to execute the optimization for my research project.
I have some questions about linking AIMMS to Python:
1) How do I execute the AIMMS file by calling it from Python?
2) Will the results be written back to Python? Or, how can I export the results to the Python workbench?
Thanks in advance, I look forward to executing my research with AIMMS...
Best regards,
Best answer by Arthur
Hi @Curious AIMMS-bot ,
We recommend you to use the AIMMS command line options to do so, as explained in the following PDF:
https://download.aimms.com/aimms/download/manuals/AIMMS3UG_CallingAIMMS.pdf
And in the following How-To:
https://how-to.aimms.com/Articles/257/257-run-batch-commands-in-aimms-command-line-tool.html
To exchange data, you may choose between the following 3 options:
- a database, like SQLite as explained in the following document:
https://how-to.aimms.com/Articles/118/118-Connect-SQLite.html
- Excel through the AIMMSXLLibrary as explained in the following document:
https://how-to.aimms.com/C_Developer/Sub_Connectivity/sub_excel_csv/index.html
- or a text file in AIMMS data format as explained in the following PDF.
https://download.aimms.com/aimms/download/manuals/AIMMS3LR_TextDataFiles.pdf
Hope it helps !
Arthur
  • October 7, 2019
Hope it helps !
Mischa
  • October 30, 2019
To make this a bit more concrete, you can use the following Python code for that:
  • Newcomer
  • October 28, 2020
Hi Mischa and Arthur,
If I understand it correctly, this will initiate a hidden aimms session to run through the MainInitialization to MainTermination procedures, or user specified procedures.
I would like to know how to link aimms as a component in my python application and also how to access the aimms command line tool from a python application.
Thanks in advance,
James
