control/change the gap
  • 19 June 2019
  • 160 views
How to control/change the gap according to what we want?
For example, I want to set the gap for 0.5% instead of 0.0%. Where should I insert the value? And how should I write the value in the AIMMS? Is it 5% or 0.5 or 0.05.
Best regards,
Zahidah Zaulir
Best answer by Marcel Hunting 21 June 2019, 15:45
Badge +4
You can use the Solvers General option 'MIP Relative Optimality Tolerance' to control the MIP gap. This option can be found in the Option Tree (menu bar: Settings - Project Options).
The range of this option is [0,1]. To specify a gap of 0.5% you should set this option to 0.005.
Noted. Thank you for the info.
