Question
Creating Subset probem
  • 17 April 2021
  • 23 views
Badge
I simply need to make a subset “test” of range from 0 to 10 of set “timehour” which the range is from 0 to 140
But I don’t archieve to do it see picture.
When i range “test” from 0 to 100 or more It works but when I’m below 100 it doesn’t
Help me pls
Userlevel 6
Badge +2
Looks like this is because you are generating a set of elements that does not contain the first ‘0’. So apparently the superset is ‘000’ to ‘140’ while the subset is ‘01-99’; so there is a leading ‘0’ missing.
Depending on what you want to achieve in the model (which is not quite clear to me), there are a number of ways that are in my opinion more efficient:
  1. use Calendars for your model (so you do not need sets as weeks and hours
  2. define this subset of timehour using the definition {index_timehour | ord(index_timehour)<=100}
  3. assure the timehour set is a subset of integers and then define this subset of timehour using the definition {index_timehour | index_timehour<=100}
Hi @jeromeee
Did Gertjan’s answer help you with your question?
