Data Exchange write out only nondefault values
  • 9 August 2022
  • 71 views
Badge
Is there any attribute which can ensure that only nondefault values are written to Excel?
Like axll:WriteTable function has writeZeros argument and if it is set to 1 then zero cells will remain empty.
Lilla
Best answer by MarcelRoelofs 13 August 2022, 23:10
Badge +6
heey @bedelillla !
yes, there is! if you are using axll::WriteTable or axll::WriteTableQuick you can use the argument IncludeEmptyRows, IncludeEmptyColumns or IncludeEmptyRowsColumns to ensure that only nondefault values are used, and the other way around as well.
axll::WriteTableQuick(
    IdentifierReference     :  ,
    TopLeftCell             :  ,
    RowDimension            :  ,
    WriteZeros              :  0,
    IncludeEmptyRows        :  0,
    IncludeEmptyColumns     :  0,
    IncludeEmptyRowsColumns :  0
Userlevel 4
Badge +5
Hi @bedelillla
DEX 1.3.2.46 will now leave all Excel and CSV cells empty for default values, by default. You can overwrite this behavior by setting the write-defaults attribute to 1 for either individual ColumnMappings or for entire RowMappings.
Prior this DEX 1.3.2.46, default values for regular ColumnMappings did show the defaults, while cells for name-binds-to ColumnMappings were left empty (unless you specified write-defaults). This has now been harmonized.
