dex::ReadFromFile not checking sheet name
  • February 6, 2024
  • 159 views
It seems that when you upload a file using the dex::ReadFromFile (dex 23.1.1.2) and using an excel mapping structure like:
<AimmsExcelMapping>
    <ExcelSheetMapping name="Demand">
        <RowMapping>
uploading a wrong sheet name does not results in a failure which I would have expected to be.
Do I need to add something to the mapping? Or is this not how it supposed to work?
Glad to hear any feedback.
Marc
Best answer by MarcelRoelofs
Hi @Marc Wingender
DEX will iterate over all sheets in the workbook and will read the data if there is a mapping with either a name or name-binds-to attribute that matches the sheet.
Similarly, this is also true for JSON/XML mappings which do not complain when a mapped node is not present in the actual JSON/XML document
Hi Marc,
I am taking a look at this, let you know when I have more.
MarcelRoelofs
  • February 8, 2024
Hi @Marc Wingender
  • February 9, 2024
@MarcelRoelofs , thanks for the reply, this clarifies the behavior. We will seek for another approach to improve our checks.
