Discrete Uniform Distribution
  • Aug 8, 2022 12:38 PM UTC
  • 103 views
Hello everyone,
Is there a way to use a discrete uniform distribution inside of Aimms? I know there is a uniform distribution but it gives me real number values for my parameter. Instead i just want integer values to be drawn from the uniform distribution. Is this possible?
Thank you for an answer.
Kind regards
Alex
Best answer by Chris Kuip
Hi Alex,
You can use round and uniform.  I created a small example as follows:
Procedure MainExecution {
    Body: {
        empty p_frequency ;
        while loopcount <= p_noDrawings do
            p_draw := uniform( -0.4999, 9.4999 );
            p_rndDraw := round( p_draw );
            ep_digit := p_rndDraw ;
            p_frequency( ep_digit ) += 1 ;
        endwhile ;
    Parameter p_draw;
    Parameter p_rndDraw {
        InitialData: 10000;
This example gives the following combination chart:
distribution of a million drawings
Hope this helps,
Chris.
Chris Kuip
  • Aug 8, 2022 2:58 PM UTC
Hi Alex,
    Body: {
        empty p_frequency ;
        endwhile ;
    Parameter p_draw;
        InitialData: 10000;
Hope this helps,
Chris.
