Discrete Uniform Distribution
  • 8 August 2022
  • 41 views
Badge +3
Hello everyone,
Is there a way to use a discrete uniform distribution inside of Aimms? I know there is a uniform distribution but it gives me real number values for my parameter. Instead i just want integer values to be drawn from the uniform distribution. Is this possible?
Thank you for an answer.
Kind regards
Alex
Best answer by Chris Kuip 8 August 2022, 16:58
Badge +7
Hi Alex,
You can use round and uniform.  I created a small example as follows:
Procedure MainExecution {
    Body: {
        empty p_frequency ;
        while loopcount <= p_noDrawings do
            p_draw := uniform( -0.4999, 9.4999 );
            p_rndDraw := round( p_draw );
            ep_digit := p_rndDraw ;
            p_frequency( ep_digit ) += 1 ;
        endwhile ;
    Parameter p_draw;
    Parameter p_rndDraw {
        InitialData: 10000;
This example gives the following combination chart:
distribution of a million drawings
Hope this helps,
Chris.
