In vs 4.74 I get an errormessage, which did not appear in vs. 4.69.:
"A function call in the initial data of a set is not allowed. Either use a definition or assign the set in a procedure.",
I see that when opening the declaration the set property is "initial data”, and I used the function elementrange for definition. However, I do not see an option to change "initial data” into "definition”. How can I repair this?
Best answer by mateusarakawa
In my project both options (Declaration and Initial data) appear:
I think your set is a local set, i.e., it is inside a procedure, right? Like this one:
If I assumed it right, local sets can’t have a declaration, because it only “exists” when the procedure runs.
So you should remove this function from “initial data”, and you can use it (populate sCalcLoop) in the begginig of your procedure code.
