Error: To run AOA the name of the AOA callback procedure should be assigned to suffix 'CallbackAOA' of 'Loesung'
  • January 17, 2021
  • 201 views
While calculating a Sum-Function  I encountered a problem  (see error message below):
While using the power of X=1 and X=2 the model works perfectly however with any other number (also negative numbers) it displays the error below in red.
Function:
Sum[p, 2 * (L1(p)+0.001)^(X) ]
Using +0.001 to avoid any division by 0 (in case of X being negative).
L1(p) being a variable which is defined by a constraint L_1(p):
Sum[i,L(p,i)] + L1(p-1)= L1(p)
And L(p,i) in the constraint being a binary parameter.
To run AOA the name of the AOA callback procedure should be assigned to suffix 'CallbackAOA' of 'Loesung'. For example: Loesung.CallbackAOA := 'OuterApprox::BasicAlgorithm'; where 'OuterApprox' is the prefix of the Outer Approximation module.
Warning: Model status 13: Error no solution, Solver status 10: Error: Solver failure (see message window).
Thank your for any help.
Hi @Marc_dm. For X=1 the model is linear and for X=2 the model is quadratic, and in both cases CPLEX or Gurobi can be used to solve the model. For other X the model becomes a mixed integer nonlinear programming (MINLP) problem which cannot be handled by CPLEX or Gurobi. How to solve these kind of problems is explained here:
https://how-to.aimms.com/Articles/192/192-solve-minlp-with-outer-approximation.html#solve-minlp-problems-with-aoa
