Font size in AIMMS
  • March 21, 2019
  • 126 views
Patrick
Is it possible to change the font size in AIMMS?
Best answer by Patrick
Unfortunately, you cannot change the font size in AIMMS itself, as it uses the Windows settings for this. In the display settings of Windows, you can change the scale and layout.
Especially when you are using a relatively small high-resolution screen, it is advised to set the scaling to 125% instead of the default 100 %.
Patrick
  • Administrator
  • March 21, 2019
Khang.Bui
  • March 28, 2019
This is very helpful. Thank you Patrick!
