Get module variable by String
  • June 3, 2022
  • 162 views
I have a String Parameter with index domain “i” called “ModPrefix” containing prefixes of modules within my project. Each of this modules has a variable with the name “Q”. Now, I would like to access these variables within the definition of a Node called “FacilityNode” like
NetOutflow = ModPrefix(i)::Q
However, this leads to the error
The identifier "Q" has not been declared, but it is declared in the modules [...].
where I replaced the names of the modules with “[...]”.
My idea of a workaround was an if-then-else-statement like
NetOutflow =
if ( ModPrefix(i) = "prefix1" ) then
prefix1:Q
elseif ( ModPrefix(i) = "prefix2" ) then
prefix2:Q
else
0
endif;
in the case of two modules with prefixes “prefix1” and “prefix2”. However, I would still like to know if there is a way to circumvent it-then-else-statements, since they become ugly in the case of many modules.
Best answer by Chris Kuip
Hi Sebastian,
You will need to create runtime identifiers, and the identifiers should be of type constraint.
Please check out:
  1. Language to create runtime identifiers - https://documentation.aimms.com/language-reference/advanced-language-components/model-structure-and-modules/runtime-libraries-and-the-model-edit-functions.html
  2. Procedure and functions that you can use - https://documentation.aimms.com/functionreference/model-handling/model-edit-functions/index.html
  3. An example that creates runtime identifiers of type constraint - https://how-to.aimms.com/Articles/131/131-Formulas-as-Data.html
With kind regards,
Chris
Chris Kuip
  • June 3, 2022
Hope this helps:
NetOutFlow =
ScalarValue(
StringToElement(
AllIdentifiers,
formatString("%s::Q", ModPrefix(i) ) ) )
  • June 3, 2022
Thank you @Chris Kuip !
I forgot to mention that this variable Q is time-dependent, i.e. it is associated with an index “t”. If I use
netoutflow =
ScalarValue(
StringToElement(
AllIdentifiers,
formatString( "%s::Q(t)", ModPrefix(i) ) ) )
then I do not get an error but it does not seem to work either, since the variables Q do not appear in the Math Program Inspector. Apparently, they are not added to the model at all. Do you know why?
Chris Kuip
  • June 3, 2022
Hi Sebastian,
Please check out:
With kind regards,
Chris
