Growth Formula
  • 23 February 2021
  • 68 views
Userlevel 2
Badge +4
Dear All,
I want to write an equation for calculating growth in a parameter or variable. As an example:
Pop(t) = Pop(t-1) + GrowthFactor(t)*Pop(t-1)
How to do this inside AIMMS?
Thank you.
Best answer by mateusarakawa 23 February 2021, 17:00
Badge +2
Hi, @rahmat .
Parameter
I tried using this approach and it worked
Code (remark: PRD → t):
popini $ (Ord(PRD) = 1)
+ pop(PRD-1) $ (Ord(PRD) > 1)
+ growthFactor(PRD) * pop(PRD-1) $ (Ord(PRD) > 1)
where popini is your initial value.
Variable
Similar to parameter. You can create a constraint as shown below:
vPop(PRD)
+ vPop(PRD-1) $ (Ord(PRD) > 1)
+ growthFactor(PRD) * vPop(PRD-1) $ (Ord(PRD) > 1)
Hope this helps!
Userlevel 2
Badge +4
Hello @mateusarakawa ,
Thank you very much for the advice given.
One more question, is there any difference between using "$" and "|" in writing formulas in parameters or variables?
Badge +2
Hi, @rahmat.
Great question. I wasn’t able to find exactly, for all cases, the difference between “$” and “|”.
I know they are similar when we are calculating or using functions, as mentioned in this page:
https://documentation.aimms.com/language-reference/sparse-execution/the-aimms-sparse-execution-engine/modifying-the-sparsity.html
In the documentation above “$” is a sparsity operator, but in some cases “$” means ONLYIF, like in the code that I worte in this topic. I know also that only “|” can be used to define domains.​
AIMMS compiler is evolving, maybe @mohansx or other aimmsian can help us finding the documentation that explains this difference.
Userlevel 2
Badge +4
Thank you very much...
