How can AIMMS solve different scenarios (initial data) at one run?
  • March 24, 2023
  • 103 views
I want to run the model with different scenarios (data), can I import all the scenarios once and get the result for each scenario in one run?
Best answer by gabiservidone
You do not have access to AIMMS PRO correct? So, to do this locally, it is a matter of:
  • Create a set of all scenarios you want to run.
  • Do a for for these scenarios.
  • Check if folder exists (/batchRun)
  • LoadCase on the for
  • solve mp
  • SaveCase on (/batchRun)
Or,
  • LoadCase
  • Change the parameter dynamically during this procedure
  • solve mp
After, to compare all cases, check this article: https://documentation.aimms.com/user-guide/data-management/case-management/managing-multiple-case-selections.html
No, you can only run one loaded scenario per time, but, you can develop a procedure that loads a scenario, delegates it, and save in a prefolder, until all scenarios are run. After that you can load all and compare them at once.
  • April 5, 2023
Thanks a lot for this reply! Can you tell me what should I refer to to realize this? Like which part of the handbook or language reference should I refer to? Or is there any article realising this?
  • April 5, 2023
  • solve mp
Or,
  • LoadCase
  • solve mp
  • April 5, 2023
  • solve mp
Or,
  • LoadCase
  • solve mp
I really appreciate this! I will try to do it with this instruction!
