How can I disable the constraints in AIMMS?
  • May 20, 2019
  • 481 views
Hello
1- I will try different constraints for my model. For example, I want to disable all constraints and show the results.
I tried to created parameters as a below;
parameter: IsDisable , range=integer
Constraint: MyConstraint , index: (i,j) | not IsDisable
But in index section in MyConstraint: " t | t>=2 "
I could not add the " | not IsDisable "
2- Also How can I write the solution to excel?
Could you please help me?
Best Regards.
Hello @inci ,
You can write the index domain of MyConstraint as below.
code:
t | t>=2 and (not IsDisable)
This constraint will be valid only when IsDisable = 0
This link is a very helpful resource for exchanging data with Excel files.
https://how-to.aimms.com/Articles/85/85-using-axll-library.html
You will be using axll::WriteTable or axll::WriteCompositeTable depending on what format you want your Excel data to be in. Review the article and let us know if you need more specific help
  • May 20, 2019
Hello @inci ,
code:
