How can I use part of an index
  • April 5, 2023
  • 84 views
Like one day have 24 hours, I need to calculate the variables for 24 periods, but these variables are defined by 25 points, so I define the index t as “25”.
For example variable A contains 24 elements, A(1) = B(2)-B(1)…...A(24)=B(25)-B(24).
 If I define an index “t” as 25, I can simply define the B as B(t) using t (1 to 25) as the domain. But How can i define A which only contains 24 elements, actually from 1 to 24, can I use part of t domain from 1 to 24?
Hi @Chunyang. You can use the domain condition t | t <> last(Periods) in the index domain of A:
Set Periods {
Index: t;
Definition: {
{ 1 .. 25 }
Variable B {
IndexDomain: t;
Range: nonnegative;
Variable A {
IndexDomain: t | t <> last(Periods);
Range: nonnegative;
Set Periods {
Index: t;
Definition: {
{ 1 .. 25 }
Variable B {
IndexDomain: t;
Range: nonnegative;
Variable A {
Range: nonnegative;
  • April 5, 2023
Set Periods {
Index: t;
Definition: {
{ 1 .. 25 }
Variable B {
IndexDomain: t;
Range: nonnegative;
Variable A {
Range: nonnegative;
Thanks a lot!
