The AIMMS webinar of August (2014) dealt with “Analyzing infeasible Problems in AIMMS”. In case you missed it, the recording can be found here. As shown in the webinar, one way to investigate an infeasible problem is by calculating an Irreducibly Inconsistent System (IIS). An IIS is a subset of all constraints and variables that contains an infeasibility. The “Irreducibly” part implies that the subset is as small as possible. Unfortunately, the IIS could only be calculated for linear (and quadratic) problems. So how about nonlinear problems?
Here 's the article
Be the first to reply!
