How-to
How to create a library of functions and procedures
  • August 25, 2020
  • 222 views
Jess Es
Creating libraries to share/reuse functionality in multiple projects is a powerful feature of AIMMS. In this article, we present some best practices and tips to create such libraries of functions and procedures.
The following are discussed in detail:
  1. Library organization - interfacing with a library is eased by a proper organization into sections.
  2. Functions - functions are popular because they can be used in expressions.
  3. Procedures - procedures are popular because they can assign new data to global identifiers.
Read more...
Hi, Thank you for the link.
I have tried to create an example for one of my problems here but I get the following error :
I am trying to create a library called optim 1 to run my problem. When I tried to create the procedure in the Public folder which would be used to map the main model arguments to first the local arguments in the library and then run the procedure in the private folder, I get the above mentioned error. It seems the error is connected to an index. Attaching screenshots below on the same. I tried to create seperate indices for the procedure in private section (t2) and public section (t1) but t1 seems to be the problem. Any help would be appreciated.
Hi @Jess Es ,
I am having difficulties in setting up a custom library. In this regard, I have one request. Is it possible to get the AIMMS file which was used as an example in the following link : https://how-to.aimms.com/Articles/334/334-data-optimization-libraries.html
Thanks in advance !
Chris Kuip
  • May 18, 2022
Please find attached,
Hi, Sorry for the delay in responding. Thank you so much for the sample. It was really helpful !
