How to exclude "na" values in Min-/Max-Operators?
  • May 27, 2020
  • 6 replies
  • 275 views
Hello together,
I have declared a parameter as an Min-Operator, which have to indicate the minimal objective function value for each k across all j.
Background: In each k at least one j is infeasible (objective function value = “na”) as certain restrictions are violated. As a result, the problem occurs that the Min-Operator outputs "na" as the minimum value for each k.
The Min-Operator’s definition is as follows:
     Index domain: k
          min(j,Parameter(j,k))
Does anybody now how to exclude “na” in the Min-Operator’s definition? Thank you in advance!
Best regards
David
Hi @David Kik In the index domain of that constraint you can use
(j,k) | (Parameter(j,k) <> inf) and (Parameter(j,k) <> na)
such that the constraint will not be generated if Parameter(j,k) equals 'inf' or 'na'.
Hi @David Kik, you can use
min(j | Parameter(j,k) <> na,Parameter(j,k))
to exclude 'na’. Note that this will evaluate to 'inf’ if all Parameter(j,k) are equal to 'na’.
  • May 28, 2020
Hi @Marcel Hunting. Your suggestion works so far. Thanks a lot!
However, as you have already noted, the problem occurs that for a given k, all parameters (j,k) are equal to 'na' which results in 'inf' for this k. Consequently, this leads to a incorrect result.
How can I exclude in my constraint (see below) that the resulting 'inf' is excluded and only positive values are considered for parameter (j,k)?
Constraint:
Auxiliary Variable >= Parameter(j,k) * Decision Variable (j,k)
Best,
David
  • May 28, 2020
Constraint:
Best,
David
Andrew
  • June 22, 2020
Hi @David Kik
Has Marcel’s suggestions helped you with your question?
Best
  • June 26, 2020
@Marcel Hunting Thank you!
@Andrew yes, a lot!
Best
David
