How to get a variable range subset of a set?
  • January 20, 2021
  • 8 replies
  • 289 views
  • 9 replies
I am working on a project of delivery planning.
In my model i have a constraint which defines the Unavailability of a vehicle for some time due to maintenance or already on a delivery. The Time a vehicle becomes unavailable is a parameter.
the constraint is :
Here,
X_v,t → indicator variable for maintenance(whether need to go for maintenance)
S(v) → time required for maintenance of vehicle v
status_v,t → indicator variable for availability of vehicle v on day t
I am unable to write it in AIMMS. how to get the range of tau ?
i was able to get the range for a single value parameter h using SubRange function
                             tau in SubRange(T, t, t + h)
but for a parameter set S SubRange is not working. Writing S(v) in place of single valued parameter giving me  this error
*There is a mismatch in the master sets of set "T" and domain set "S" in the first argument of the call to intrinsic function "SubRange".
  • what could be a possible solution for writing this constraint if S(v) is a parameter Set?
  • what if S(v) is a variable set?
Best answer by deannezhang
Instead of using a set with index, i.e. S(v), the convention is to use numerical value, i.e. maintenance_length(v), which indicates the length of maintenance period of v. Then since the period is an ordered set,  condition below will do the same
t<=tau<=t+maintenance_length(v)
deannezhang
  • 61 replies
  • January 21, 2021
Patrick
  • Administrator
  • 54 replies
  • January 26, 2021
Hi @roy , did Deanne's answer solve your issue?
  • 9 replies
  • February 4, 2021
no, not really.
  • 9 replies
  • February 4, 2021
t<= tau <= t+maintenance_length(v)  is not working.
ploblem is occuring when t+maintenance_length(v) is larger than last element of TimePeriod Set, where t is an index of Timeperiod.
  • 9 replies
  • February 4, 2021
t<= tau <= t+maintenance_length(v)  is working partially.
deannezhang
  • 61 replies
  • February 5, 2021
what problem do you encounter? I would have a look if you share it here.
  • 9 replies
  • February 9, 2021
it was giving erroneous result, not as I expected.
But i was able to fix it by slightly modifying your approach.
i rewrote the condition as, t <= tau <= t + min{ maintenance_length(v), (Last(Timeperiod) - t) }
and now its giving expected result.
Thanks for helping me to resolve this issue.
deannezhang
  • 61 replies
  • February 9, 2021
if tau is an index of set TimePeriod, the min function tau <= t +  maintenance_length(v) should work, since it won’t go over the bound. I don’t know why it doesn’t work in your case, but I’m glad you make it work.
