How-to
How to identify data differences after refactorization
  • August 12, 2019
  • 53 views
Jess Es
We'll show you a streamlined process to identify the cause of data differences in a model after a refactorization using a diff tool.
The process we’re following can be summarized like this:
  1. You’ll want to separate out each element, so it will be easy to break down the differences.
  2. Then send each identifier to a separate output file in an output folder.
  3. Do that for each version of the model, so you’ll have two output folders each containing output files to be compared.
  4. Finally you’ll compare the two output folders with a diff tool to find the differences between the individual files.
Read more...
