How to raise warning before closing WebUI tab?
  • October 8, 2020
  • 203 views
Hi All,
For a project we are implementing a user is making changes to a relatively large table. The user has the possibility to store these changes in a database.
However, when a user closes his/her browser after having made these changes and forgets to store the changes in the database the changes have to be made all over again. Is there a way to raise a warning when closing the browser? In this case that would refer to a user that has made changes, but has not stored them in the database.
I know using a uponleave procedure works when navigating to a different page, however when closing a tab no warning is raised using such a uponleave procedure. Furthermore, I have seen multiple sites raising a warning when closing the tab, so curious to see if this is possible to do in the AIMMS WebUI as well!
Best answer by MarcelRoelofs
Obviously, there are more scenarios to consider where the connection to a webui app gets closed than just closing a browser tab, e.g. the user closes the browser altogether, laptop battery drained, BSOD, …
Therefore, shouldn’t you rather consider protecting against lost edits inside the model? There are at least two options that come to mind without even thinking this through very thoroughly:
  • The WebUI has an option to save a case when the backend session terminates, and open that case the next time a new webui session opens. You could also setup a similar scheme by coding this in PreMainTermination & PostMainInitialization yourself, where you have the option to better control when you want to trigger the use of such a mechanism.
  • Use CDM to automatically store user edits as soon as they are done. This would also allow undoing changes based on the history. As a bonus, CDM would allow multiple users to make changes to the data in a consistent way.
Hope this will give you sufficient ideas to continue.
MarcelRoelofs
  • October 9, 2020
