There are times you might want to save a case from within a procedure.
For example, let’s say you want to run multiple scenarios and store the result of each one to a separate case. Instead of manually saving a case after running each scenario, you can save cases automatically with a procedure.
That way, you can run a procedure that solves all your scenarios and saves cases after each solve, and let it run unattended.
Read more...
