How-To
How to use multiple indices for one set
  • June 5, 2019
  • 164 views
Jess Es
You can use different indices to refer to the elements of the same set.
Suppose we have a set,
code:
Cities
, and a parameter,
code:
Distance
. We want to define
code:
Distance
over 2 dimensions (
code:
from
and
code:
to
) for the same set,
code:
Cities
If you didn’t know that AIMMS can handle multiple indices for a set, you might create two new subsets
code:
CitiesFrom
and
code:
CitiesTo
, containing all elements of the set
code:
Cities
, and each with its own index.
Luckily, you can just assign multiple indices to one set.
Read more...
