How-to
Identifier Naming Convention for How To
  • 7 October 2020
  • 164 views
Badge +7
At AIMMS User Content we made a choice regarding the naming convention to be used and would like to share the considerations we had to derive at our choice.
  • What do you think?
  • What are the considerations you used for the naming convention you use?
see Identifier naming convention
Userlevel 3
Badge +4
Hi Chris,
Nice article on the naming convention! As you know it is very close to the convention we use at CQM.
One additional thing in our naming convention that I like to share, is that we prefix identifiers that are locally defined differently by adding an 'l’ for local. So, a parameter locally defined within a procedure becomes ‘lp_..’ contrary to 'p_...’ for global. We encourage the usage of local parameters and procedure arguments to get better maintainable code, and a specific naming style helps in that respect.
Regards,
Jacob Jan Paulus
Userlevel 3
Badge +4
I'm curious hear more on AIMMS' vision on the broad subject of code style and organisation. Naming convention is just a part of the style.
Within AIMMS the developers have extreme flexibility on how to structure code and workflows, which becomes a pitfall for larger projects when there is no guidance on the style and structure. Flexible use can quickly create chaos.
I know this is a really big question: Can you give guidance / best practices on how to structure code?
Just some of the questions from the top of my head:
  • How to best organisation of sections / declarations?
  • When to use a module vs a library?
  • How to setup use cases and workflows (in combination with WebUI)?
  • When (or should) there be a model, view, controller design pattern?
Badge +2
Hi Chris,
Regards,
Jacob Jan Paulus
Great addition, Paulus. We use some prefixes for parameters that are arguments from a procedure/function. E.g. p_”arg”_name.
We also use other prefixes to easily identify if a identifier is related to interface only (p_”gui”_), or if it’s just a pre-calculation for the optimization model (p_”exe”), or if it’s just direct result from the model variables (p_”exs”_), and so on.
