If statement in constraint
  • July 5, 2019
  • 2290 views
Dear all,
In my model, I work with multiple factories. Each factory has a minimum lotsize requirement, meaning that IF a product run is initiated, it must be at least xxx big. I tried to put it in as follows:
  • I have a parameter MinimumSKULotsize(f), which specifies the minimum lotsize per factory;
  • I have a binary variable ProductInFactory(f,p,t), where 1 indicates a production run of that product at that factory in that time unit, and 0 does not.
  • I have a variable ProductionAllocation(p,f,t) which indicates how much of each product is allocated to which factory at which time unit.
I tried to add the constraints:
SKULotsizeConstraint0 with index (f,p,t) | ProductInFactory(f,p,t) = 0 and definition
ProductionAllocation(f,p,t) = 0
SKULotsizeConstraint1 with index (f,p,t) | ProductInFactory(f,p,t) = 1 and definition
ProductionAllocation(f,p,t) >= MinSKULotsize(f)
However, I am getting the warning: Warning: The index domain contains the variable "ProductInFactory". The use of a variable in an index domain is not allowed.
Before this, I tried to do it with an if-statement, but then I was also met with several errors. My question is: how could I correctly apply such a constraint in this situation?
Kind regards,
Koen
Best answer by deannezhang
Koen,
Domain condition can only contain parameters. Variables cannot be used as domain condition. You need to linearize your constraint:
if ProductInFactory(f,p,t) = 0 then ProductionAllocation(f,p,t) = 0
if ProductInFactory(f,p,t) = 1 then ProductionAllocation(f,p,t) >= MinSKULotsize(f)
trying yourself first, if not people here can help
deannezhang
  • July 8, 2019
Koen,
Jess Es
  • Grand Master
  • July 25, 2019
Hi @KoenV did this answer your question? If so would you please mark "best answer" so others can find it easily? Thanks 🙂
  • Newcomer
  • June 27, 2020
Koen,
hello.. how to write the constraint like this in the model? should I write it in the constraint or in the variable?
In my model there is a binary variable x_jm(i,m,k,t) means that route selection from i to m using ship k in t time. And there is a positive variable UF(k) which is the Utilisation Factor of ship k. There are some ships in index k, not all of them to be selected/used. So once ship k (let’s say ship k1 and k2) are selected then those ships must have utilistation factor UF(k) above 0.7.
I put the constraint like below picture but there is a warning.
Could somebody help me how to write it in the model?
Thanks.
Regards,
Ardhana
HI @ardhanaa. You cannot formulate this in one constraint or variable definition. You can reformulate it by using the following constraints:
sum[(i,m,t), x_jm(i,m,k,t)] >= b(k)
sum[(i,m,t), x_jm(i,m,k,t)] <= M * b(k)
UF(k) >= 0.7 * b(k)
UF(k) <= N * b(k)
Here b(k) is a (new) binary variable, and M and N are upper bounds on sum[(i,m,t), x_jm(i,m,k,t)] and UF(k) respectively.
